Technical Handbrake recall spring/warning light switch
Hi there,
I have a slight issue with the handbrake warning light staying on after the lever is released by pressing the button on the end - though the handbrake itself is working as it should. It just means I sometimes have to manually move the lever to the down (off) position to get the light to go out. Possibly due to a partially worn, tired spring (which corresponds to number 14 on the attached diagram taken from ePER), or the handbrake switch sticking.
Any advice or feedback welcomed.
Cheers,
Andy
Year
1993
A bit more info...on closer examination the warning light sometimes remains on when lifting the handbrake lever, which stays in this position, without pressing the button on the end. Not sure if this indicates the internal spring or switch is at fault? Alternatively, does the ratchet mechanism need regreasing?
Hi all,
Does anyone have any thoughts on the issue mentioned or have you come across something similar? I think as a first step I will check the handbrake cables to see if there are any obvious problems before examining the area around the handbrake lever and switch.
Generally I'd be checking the actual switch contacts and operation first .... the switch will be confirming the actual H/B lever is fully down, not related to the pawl/rachet release button.
Depends if the switch is normally open or closed when H/B is selected , could be physically sticking or just tarnished contacts.
Thanks ZaphodB. I'll check the switch though the handbrake itself does not release fully unless moved manually, independent of whether the warning light is on or off.
