Technical hand break light flashing
pete123
Established member
Essex
Another multi prob sat in tesco car park and noticed when the hand break is applyed and u move about it flashs is this a loose conection from under the rubber boot or is it a early sign of some thing worse to come hand break is fully working its not high when lifted so I lost with this one
it's always easy / cheap first / by %
- most times it's electrical not pysical so go for the connections both physical and electrical under the boot inside the car
- I has an unimportant but soddin irritating warning light sometimes but indiscriminate .. .. I pulled the rubber boot and gave it a clean then a wellie with WD40 - never seen it since (y)
Must be a dodgy connection in the bootas when I shake the car it goes on and off at min it not showin noting ill check it in morning and let ya no how I get on
All sorted the cable was loose running in to the rubber boot thanks for advice
