General  Grinding noise
wazzie
Greetings,
i've developed a grinding noise when i pull my steering wheel left, ive checked the power steering fluid. Input would be greatly appreciated....
Cheerz
Aside from the the obvious opening to a funny - 'Could it be your teeth?' - is this with the car stationary or on the move?
My first thought was worn brake pads!
Peat
Greetings,
the noise is when im mobile m8!
ChEeRs....
If the car is on full(ish) lock and you get a grinding sound I thought that means the driveshaft CV is gone and will need to be replaced? Is the sound on full lock?
The sound starts as soon as i start to turn left only....
ChEeRs
ChEeRs
Just hoping it's something a simple and cheap to do! (sometimes we are lucky)
Have you tried looking to see if the tyre or tyres are catching on anything around the wheel arches?
I know it's a long shot but it's worth a look.
Fingers crossed (y)
My garage man confirmed the cause of my noise, metal thingy behind the front break pad was rubbing. Cost nothing to fix!
Thanks for the input tho!
