First, thanks to everyone for their time and suggestions. jackwoo actually is the closest guess.
Just to address the issue, there is no circlip on the inner joint splines on this vehicle. Not sure exactly what the retaining mechanism is, but I measured the depth of the oil seal and it bottoms out at 15mm, the oil seal portion of the shaft is about 23mm and when installed I measured about 8 - 9mm space, so the shaft was definitely in all the way.
I removed the axle and noticed the new outer CV joint seems oddly loose, play with it a little and realize it's almost completely off the axle! How can that be? I open the boot up, the joint slides right off as only the tip of the axle is in the joint and I see the Circlip is missing! I stick my finger up into the CV joint and find the clip is shoved up into the joint! Not sure how that happened. Apparently the grinding I was hearing was coming from the CV joint side, but I couldn't tell the difference because I was up in the cab and I just assumed it was from the gear. As far as I can figure however the circlip came off, the shaft worked it's way out of the CV joint and when I would smack it I was basically just knocking the end of the shaft back into the CV joint, but it would quickly work it's way out again...
Back to the CV joint, the new clip that came with the joint seemed a bit big, I tried pressing down the ends of the clip without success and just hammered the joint on. I checked and it's seemed snug before I installed the driveshaft... Crazy!
