Back in the '60s, when cars like the Mini 1100 Maxi etc were making front wheel drive the norm, CV joints were nothing like as long lived as today's products. Renewing joints and boots was quite a common job and when I considered how the joint actually works - large ball bearings rolling back and forwards in grooves all made from very hard metal - I decided to experiment to see if I could improve on the lubrication. I'd observed that often when an old joint had failed (where the boot was not at fault - early boots used to fail with monotonous regularity) the grease had solidified to some extent and was no longer distributing itself around the balls and grooves. I started adding about one to two teaspoonfuls of heavy gear oil - EP 120 was often what I had lying about - and I found that, unless a boot had failed, the joints seemed to last much longer. They were very messy to strip down though but the, now semi liquid, lubricant was distributed all around the working parts. Since then I've always just used Moly grease from a tin - if there's no grease supplied with the new boot - and added some heavy gear oil to it and don't really have any problems with driveshaft joints. My old Cordoba diesel got new boots at somewhere around 40,000 miles. Because one boot was leaking I just replaced both, adding my "special brew" and she was still going strong well into the low 100,000 miles when I scrapped her due to structural rust and engine fuel system problems.
