It is but is a little harder to do on the 1.9 you need to take the wheel off and remove the wheel arch lining to get to the back of the fog light unit to replace the bulb nit a 5 min jib but probably take around an hour to do if you took your time maybe a little longer if you cleaned everything while you were at it
it says in handbook its f31 15amp but its 20 amp that's in also all other fuses appear to be wrong amps according to handbook, also do you know where the fuse is for cigarette lighter as this is not working too,
