So for all thos who followed my thread regarding the overheating/running hot once at speed especially on the motorway. Well I think I've finally sorted it. I recently changed the water pump (although the olf one wasn't plastic and wasn't slipping) changed cam belt and tensioners at same time, problem was still there, noticed bottom hose was stone cold even after a long run on the dual carriageway when temp was above halfway. So ordered new thermostat, emptied coolant, added some decent rad flush and gave it a good run, emptied all out, back flushed the complete system especially the radiator. Fitted new thermostat, replaced the bottom rad hose and top rad hose, added new coolant and took for a test drive.
Noticed it takes quite some time to reach normal operating temperature even when driving around 10 minutes maybe more. Doesn't go above halfway now on the gauge (90) but what I have noticed is that when criusing at speed it stays at 90 but as soon as I slow down junctions, round a bouts, town etc, the temperature drops slightly below 90
Is this normal?? or could it be some trapped air stil lin the system?
Also noticed that unlike before when I unscrew the expansion tank cap there used to be air, now there is none at all which is a good sign. Speaking to a mechanic who explained to me that if the water isn't circulating properly either through faulty water pump, radiator or thermostat. Pressure can build up, like a kettle as an example.
