Technical Glow Plug Relay.
My relay was changed a while ago and I just want to make sure it is the correct one that has been fitted. Ducato 250 / 2.3 / 150bhp.
ePER didn't filtered my search results (it does that sometimes), but I found theese relays. I don't know if this helps you in any way. If I can find something more specific, I'll post it.
Does anyone know the correct Part No. for the above. Ducato 2014.
I don’t have the exact part number off‑hand, but for a 2014 Ducato you want to double‑check the VIN or engine code before ordering any glow‑plug relay. Other folks on here might have used [part‑number X] or [part‑number Y], so worth asking if someone with the same engine can confirm. If you check with a local Fiat/Peugeot service centre or parts supplier, they’ll be able to look it up correctly too.
