£300 is not bad for the clutch too, but it's 240 miles round trip from darkest Rutland to Bradford so might try someone nearer to here but thanks for the info.I have a guy not more than a mile from me who did my 4x4 panda gear box for £300 That was for removal from car and throw a load of new bearing into it and fit a clutch kit that I provided. His location BD13 1LP
I've had a look on ebay and ZC 90 looks to be expensive and noted that gearbox oil has been a topic of much debate with 15W 40 engine oil being a suggested alternative which has similar viscosity. I'll try cahnging the oil and see if this helps before considering the gearbox rebuild.just changing the oil *may* fix the problem, you need to get hold of SAE 85/w90 GL3 oil otherwise known as "ZC 90".
theres some for sale on ebay at the moment. if i remember correctly, you need 2 and a half liters. for the panda box.
make sure the CV boots are in tip top condition. on these gear boxes the CV boots hold the oil in so if one perishes and splits, you loose a lot of gear box oil. (the cause of many cinquecento gear box deaths i find when walking around our local scrap yard )
Thanks for the info will use 20w50 as suggested.If it is the syncro then changing the oil will not make it any better, it should help stop it getting worse though. Use 20w50 not 15w40 if you cannot stretch to ZC90.
