Technical  Gearbox magnet
Punto Evo active feelin good, 2010 reg 1.2. 8 valve petrol....5 speed gearbox.
I understand this gearbox is fitted to other fiat model cars using the 1.2 8 valve fire engine.
There is a magnet inside the he gearbox, relatively close to the diff *crown * .
Does anyone know for definite, is the magnet visible via the g/box oil drain plug hole please ??
I suppose it's way to much to ask of fiat if the magnet is easily removed via this drain hole......Hoping against hope with that one I guess, but you never know....
WHY new thread?
Continue here: https://www.fiatforum.com/threads/e-learn-way-in-gearbox-guide.522837/ !
Forget about the magnet. There's nothing you can do (without opening the differential, removing the cover).
view
