Styling  Gear Nob
Styling  Gear Nob
Hei.
Actually you'd bette forget it. You can chop off the stick and glue another knob on to it. Result - shorter gearstick. There is another thread on the Uno forum that covers this.
Morten.
Sorted,
un bolted outer sleave, carfully removed rubber nob. cut top off plastic, then after replacing outer sleave I attached new nob to metal inner shaft. looks great (well as good as a custom nob can) and works OK, but have to push lower shaft seperate from nob to use reverse.
Brutas
