Technical Gear box stuck in 5th and reverse
Ryantsmith
London
My Fiat punto evos gear box can currently only go up and down between 5th and reverse gears. There is a resistance when trying to put the car in neutral or in 1,2,3,4 gears. Not sure if it’s a gear box problem or a linkage problem so any recommendations are appreciated thank you
More than likely a linkage problem. Easy to check if you pop the linkage off at the gearbox end and still see if you have the resistance on trying to move the lever.
Easy to do if it is something like a 1.2 or 1.4 as the linkage is just below/beside the battery and fairly easy to get to.
Hi thank you for the response! I know it’s a general question but how much do you think the repair would be if it was a linkage problem compared to a gearbox problem?
Thanks in advance!
