Fuse Box connection
Fuse Box connection
SE London
Hello, I'm installing RCL & I was just wondering if anyone could tell me how do i connect the wire in the picture into the brown connector? I need to plug it in to position 20.
I presume you need take the brown thing apart somehow but cant figure it out....
Sure u can get the brown connection apart :) there is a lock in it in both sides if u nnoticed that just use a sharp knife or something and press on the lock in the same time u take it off with ur hand its easy dont afraid.
Yeah, i noticed the little clips on the side but couldnt seem to get it apart. I'll try again with a knife :)
Which way do you push it though? From the end closest to the little clips, or furthest away from the clips?
Just push the little clips to inside from poth sides and get the cover of the connection out. but i think that u need to change the termal of ur connection its to big anyway when u open the cover u can decide if it will work with u or not .
