Technical Funny engine vibe, 2.8tdi (i.d.TD)
dukebus
Dublin
Hi folks,
2000 Ducato 10 2.8 Panorama (left hand drive)
Hopefully someone might throw some light on this (either a cause or a "they all do that...")
Under heavy-ish cornering (fast sweeping bends..) I get a vibration coming through the wheel arch foot rest. A bit like a cv joint on the way out. However, it seems to only be there at 2500+ rpm (4th or fifth) Its not an issue in 5th gear, as I dont corner *that* fast :) The intensity of the vibes depend on how hard your cornering. So, is it:
a. cv issue
b. gearbox/diff issue or
c. sone engine harmonic/bearing issue?
any experience in this would be appreciated!
duke.
ok,
dont think its either cv or gearbox. Seems to make the noise gently at 2500rpm on a straight road, but knocks merry hell when cornering. Could be a loose or broken engine mount?;)
duke
