Technical full beam don't work
Essex/Suffolk border
got no full beam, i flashed a lorry out yesterday and full beam light came on the dash an stayed on, i turned ignition off and re stated car and it went out, but now full beam no longer works nor does the light on dash.
is relay T02 onder the bonnet the right one for full beam? ive changed that but still no work :(
I didn't get a warning from the car when my full beam bulb blew, and I believe they're linked - I'd check both bulbs for continuity if you haven't done so already, also see if they're getting power.
had a look on ebay and if i had a vectra I'd be able to get all the stalks seperate, but thats one bit that isnt the same for us. FF eper is listing it as £1.33 + vat and that's years out of date so may be more :( have emailed the guy breaking one on ebay but dont know if he will have it, every thing else ive asked him for has already been sold.
There are two people on ebay breaking Cromas, one seems a bit more realistic with his pricing than the other. Keep looking :)
i took mine off and it rattled if i turned it upside down stalk would stay parked for both directions , inside a bit of plastic had broke off the end and a metal rod was out of place, i put rod back and stalks seemed to act normal when i put it back together, so fitted it to the car, now i have no full beam an no indicators at all :cry:
And I thought it was just me that these things happened to.
E.g within 4 weeks I had the following:
Fix Sceicento thermostat and water pump fails
Fix water pump and radiator fails
Fix radiator and head gasket fails
Fix head gasket and sell car.
