Technical Full Beam adjustment
Oundle
I have a 2014 500 Lounge and the full headlight bulb is situated in the day light housing. This model's main/dipped beam is in the large lamp.
When full beam is selected the day running light goes dim to allow the full beam to shine below the dipped headlight
Can anyone tell me how to raise or lower the height of the full beam? I know how to change the bulb
There is 1 adjuster but not sure if it's height or side to side, but first check the whole cluster is correctly mounted and that the mounts haven't come away from the inside of the bumper?
On earlier cars like ours the bulb is held in place by a clip that's secured by a screw! Is quite fiddly to replace and there's every possibility you'll drop said screw into the rear of the cluster, if you want to try, wheel off possibly arch liner removed?
