My 500 has developed an intermittent fault.
Occasionally it loses power revs drop off and if the accelerator pedal is pressed the revs wont pick up. although it doesn't cut out. This lasts for about 10 - 15 seconds then it returns to normal.
This has happened at low revs and at idle.
This started on the way home from work after about 4 miles and repeated every day at the part of the journey.
I have swapped the carb with a recent rebuilt one and I have swapped the fuel pump with a known working spare. The issue is no better and no worse.
I will swap the distributer next. Maybe the bob weights are playing up.
I'm inclined to think it's carb or distributor as they are the only components that have a separate idle and fast running function.
If anyone has experienced anything similar or has any suggestions please let me know.
