Technical Fuel rail tabs broken
Andrear984
United Kingdom
Hi everyone,
Thanks for the all the tips and guides on this forum, they've been a great help in keeping my 2016 Fiat 500 (1.2 E6) in good shape. Approaching 92k miles I decided to replace the injectors (irregular idle, excessive vibration etc) and found a good deal on 4 new Valeo.
When I tried to the disconnect the fuel pipe from the fuel rail the 2 plastic clips "quick release" literally broke off like they were made of sugar. I managed to replace the injectors with the fuel line attached no problem but now I am missing those 2 tabs, everything else in place and car now runs smooth as silk. Should I worry or can I just get along just fine without those 2 tabs? I would guess the fuel line will be secure unless those 2 tabs are pressed.
Model
Fiat 500 Pop
2016
Mileage
92000
Ahhhh gotcha 👍
Maybe rig something to emulate the clips function just for safety's sake , high temp cable ties etc
I had a similar experience to yourself when swapping injectors!.
And then got paranoid about the rail separating whilst driving! Once i figured that i was probably never gonna try and take it apart again and if anything else went wrong in that area i was going to have to get another (new?) one! i decided to(correct)the problem .
I drizzled a little epoxy resin(araldite) into the recess where the clips sat to insure it stayed together (having said that the connection still felt solid despite the lack of clips) left it overnight to set and have not even thought about it since!.
Hi there, I was a bit paranoid too at first, then realized that these fuel connections are actually pretty fail safe. Out of caution I may not epoxy the whole thing just yet, I used some high temp tape to cover the openings where the tabs were, just not to get any dirt in. Clearly quite a common problem because half of the used fuel rails ("flauto iniettori" if you look up the Italian sites) on sale on eBay are already broken
Thanks everyone!
Thanks everyone!
Thats why i said that if i was ever to replace mine id be getting a new one! 😁
