Bit of an update..
Remove the petrol cap to ease any tank pressure before removing the pump - had a think about it before starting so I didn’t get a face full of fuel
Tie string to both pipes and the wires in case they drop down. I’d guess it will be a bugger to re find them if they drop down.
I removed the fuel pump to check if the rotor was just blocked / jammed..
Gave it a knock and connected it direct to the battery and... No Joy
Scratched my head and tried it reverse polarity and hay presto Bzzzzzzzz
then in forward Bzzzzzzz
Put it back in the car and after priming a couple of times, locked up again.
So without removing the pump I reverse polarities it by removing the rear 2 pin connector and putting 12V the wrong way across the pins (with a fuse inline just try each way till you can hear it Buzzz), then reconnected the proper wire and got my car going.
Its now a bit hit and miss, so I think I'll need to remove it and flush the pump fully..
Till then I have the kit to reverse polarise the pump each time it fails.
This is the pump on the assembly which contains level sensor
However the Electric fuel pump can be split from the assy and serviced alone
This bare fuel pump (apparently) also fits "SYTEC REPLACMENT IN TANK FUEL INJECTION PUMP
FOR IN TANK PUMP MODELS ONLY
SUITABLE FOR THE FOLLOWING MODELS
BARACHETTA 1.8 16V (SRIS) 1998 - ON
BRAVA 1.4 12V 10/1995 - 10/1998
BRAVA 1.6 16V 1996 - 1998
BRAVA 1.6 IAW / 16V 5/1995
BRAVO 1.6 16V 1998 - 2000
BRAVO 1.8 16V 1995 - 1999
CINQUECENTO 1.1 SPORT >10/1994
CINQUECENTO S/SX 1992 - ON
COUPE 2.0i >4/1994
COUPE 2.0i 16V 4/1994 - 9/1996
COUPE 2.0i 20V >10/1996
CROMA 2.0i 16V >11/1992
CROMA 2.0i 16VB MOTRONIC >1993
CROMA 2.0i 8V 1990 - 11/1992
CROMA 2.0i LU 1990 - 1992
CROMA 2.0i LU >1993
CROMA 2.0i IE LE/LU 1985 - 6/1990
FLORINO 1.4i/MONOPOINT 9/1993 - 6/1995
FLORINO 1.5i/MONOPOINT 1988 - 8/1993
FLORINO 1.6i/MONOPOINT 9/1993 - 2001
MAREA 1.4i 12V 10/1996 - 2/1999
MAREA 1.6 16V 1996 - 1998
MAREA 1.6 16V BI-POWER 1997 - 1999
MAREA 1.8 16V 1996 - 1999
MAREA 2.0i 20V 10/1996 - 2/1999
PANDA 1000 IE / 4X4 1986 - 3/1997
PANDA 1100 IE / 4X4 / SELEC 1986 - 1992
PUNTO 85 1.2 IE 16V 1997 - 1999
PUNTO 90 1.6 IE 1994 - 1997
PUNTO 90 ELX 1996
REGATTA 75 IE 5/1987 - 6/1990
RITMO 75 IE 1.5 5/1987 - 1988
RITMO 90 IE 1.6 5/1987 - 12/1987
STRADA/RITMO 75 IE MONO-JET 1987 - 1988
STRADA/RITMO 90 IE MONO-JET 5/1987 - 12/1987
TEMPRA 1.4 IE/SW 3/1992 - 3/1996
TEMPRA 1.6 IE/SW 6/1990 - 1996
TEMPRA 1.6S MONO-JET 1990 - 4/1993
TEMPRA 1.8i 1990 - 3/1993
TEMPRA 1.8i 4/1993 - ON
TEMPRA 2.0i 4X4 3/1992
TIPO 1.4 IE 5/1989 - 3/1993
TIPO 1.6 IE/SELEC 3/1990 - 10/1995
TIPO 1.8i 16V 6/1989 - 1991
TIPO 1.8i 8V 6/1990 - 1992
TIPO 2.0i 16V IAW 1991 - 1992
TIPO 2.0i 8V 3/1990 - 1992
TIPO 2.0i IAW >1992
ULLYSSE 1.8 HL (COMPUTER) 1996 - 1998
ULLYSSE 1.8i SX/EL (NO COMPUTER) 1996 - 1998
ULLYSSE 2.0 HL (COMPUTER) 1996 - 1998
ULLYSSE 2.0 TURBO HL (COMPUTER) 1996 - 1998
ULLYSSE 2.0i SX/EL (NO COMPUTER) 1996 - 1998
ULLYSSE 2.0i TURBO SX/EL (NO COMPUTER) 1996 - 1998
UNO 1.0 IE SPI 1989 - 1994
UNO 1.1 IE 9/1989 - 3/1994
UNO 1.4 IE 1989 - 1994
UNO45 IE / FIRE / VAN 10/1987 - 3/1994
UNO 70 IE 9/1989 - 3/1994
UNO 75 IE / SELECTA 9/1987 - 3/1994
UNO FIRE 10/1987 - 1989"
I was Under the impression that the MK2 Uno with carb (1990 - 1992) has a mechanical fuel pump :S
