Hello!
Is replacing the fuel filter an easy do-it-yourself job or it is complicated? What is required, other than a new filter of course?
I would like to replace my one because, even if I rarely use the car on gasoline (I mainly use LPG), if I have to use it on gasoline then the car is like "stuck" when starting, I have to press the accelerator pedal a lot or it will "jump", so I think it could be a dirty filter with poor gasoline delivery.
Is the fuel filter located near the engine or it is at the back, near the fuel tank? I am asking for a Tempra 1.6 SX with carb, should be much similar to Tipo 1.4 (don't remember if there were 1.6 Tipos with carb or they only were i.e.)
