So still not sorted. I haven't been able to locate a fuel cutoff and think that there isn't one on this vehicle. That would make sense looking at airwave's comment (thanks airwave) I have replaced the fuel pump (mechanical) replaced starter and checked that fuel is being supplied to all injectors. Anyone have any other ideas. Thanks also to communicator for your suggestions No problems in air filter. The vehicle was driven 30 miles whin the bump happened. I am wondering if it is possible that the timing belt has slipped. I have no idea how to sort that myself so i am looking for a mobile mechanic who could take a look. I am in galway,ireland
Just so we can get this one outta the way here . Try operating the starter , with the lights switched on .
Now i say this , because you have , or at least i assume you have two of the main elements for ignition . There really is not much that can go wrong with older diesels , that's why i have two . Of course i'm assuming diesel is actually reaching the injectors . That instantly leads me to think your battery could have a problem .
Have someone stand in front of the vehicle , while you cranking the motor over . The lights will dim , but only very very slightly . Any more would indicate an issue , but not necessarily a faulty battery . Though it is possible it could be breaking down under load . Check the battery connections are tight , as is the main chassis earth . Mine is directly below the battery on the main chassis member . If these are fine and the battery is old , maybe it would be worth having it checked . Any good tyre centre , who market batteries should be able to do this , else try a local medium sized garage .
On a vehicle of this age , i would also take a look at the starter motor connections . A poor connection here will lead to reduced power at the starter . On my duke (a year 2000) , the starter motor is mounted on the front of the engine , low down , and a previous owner had removed the belly pan . The state of these heavy duty connections was not what i would have classed the best . As my engine basically has what is a 2.5 lower block , i would guess yours will be the same place .
Another area worthy of consideration , is the engine earth strap . Somewhere there should be a heavy cable , earthing the engine to the chassis . Normally this is a braided cable with no outer sheathing . A quick get out of jail card to play here , would be a jump lead . Connect to a good earth on the chassis , and the same on the block . Make sure it's clear of any rotating parts , but i would not recommend earthing directly to the battery . My understanding is , these straps are prone to problems , yet the interesting thing here is , i've yet to find mine !
I suspect the starter earth strap may well , perform both tasks .
There really is no reason to assume anything's wrong with your timing , at this point . Unless you have good reason to think otherwise , for example someone has been fiddling .
A minor bump , is highly unlikely to have altered , or give cause for the belt to slip .
