[/img]
thats why the MF2 approach is, well, flawed. iirc some of the vad cars had the stock ECU remapped with a 'better' spark table. but not all (not even many) did.
Nope they had a chip rather than a re-map..
[/img]
You know that changing the fuel pump will give no more fuel pressure, it may give more L's per hour, but it will still run at 0.8-1.2 bar as per Fiat, the pump does not change the pressure, the regulator does.
You need a separate regulator fitted like this diagram shows, do not just fit it inline as the fuel will always take easiest route, ie through normal regulator.
Can't remember the website now....but i often use this company http://www.diyautotune.com/catalog/wideband-systems-c-23.html
There is also http://stores.ebay.co.uk/efi-solutions aka http://www.efilive.co.uk/ .. a guy called Richard Ingram. His prices and service are keen, hes an official distributor, and delivery is from the UK and next dayIf you want any extras like guages, give him a call.
Cheers,
Kristian
I use a 4.3v Zener diode - not a transistor.Tricker uses just a resistor places between the map sensor pins on his turbo setup to stop the car seeing boost its a mod for less then £1
