- Joined
- Jan 20, 2010
- Messages
- 110
- Points
- 43
Hi, £70.00 for a full tank? went to Manchester and back and now on red? 400 miles = 33 miles to the gallon, average 60-70 mph...Is this good or do I need to look for an issue?
I wasn't sure what to expect on a long run! I have a 20v na 'standard' so thought I may get a little more than the turbo/modified model and I kept it at a steady speed. ThanksThats more than good its Fantastic
7.9 !!! lol, sounds like fun. So 33 mpg not too bad. If there was a reason for not getting a little more mpg, any ideas on what it could be? no fuel leek, been serviced and runs great. Somebody mentioned on another post about a lambda sensor failure could increase fuel consumption??? Thanks33 mpg out of a 20v N/A is a decent average, but its not brilliant if you've only been cruising at a steady 60-70
I get a bit less than that as an average out of my mad-modded turbo, but at a gentle (sub-80) cruise, I get an easy 35mpg, with a best ever of 43mpg
Worst was 7.9mpg
33 MPG is fine so stop worrying.7.9 !!! lol, sounds like fun. So 33 mpg not too bad. If there was a reason for not getting a little more mpg, any ideas on what it could be? no fuel leek, been serviced and runs great. Somebody mentioned on another post about a lambda sensor failure could increase fuel consumption??? Thanks
Your'e right ! I'll wait and see what the emmisions test is like when the mot is due next month. You just read so much about certain issues and it gets your mind working overtime. Thanks33 MPG is fine so stop worrying.
You are looking for a problem that is not there.
A faulty lambda would be picked up at MOT time with high emissions
I usually do the same. But on a long run I thought it best to fill up from home (£127.9) because it's motorway all the way. We all know how much they like to charge for fuel at the services...I can't remember the last time I brimmed any car of my own. You're losing fuel carrying round that extra weight, 50 litres must be heavy. My coop lives in the 1/4 tank territory almost permanently
Hi, just been to sainsburys to fuel up and I was surprised to see the fuel prices...£127.9 REG 95 £130.9 97 HO so I thought I would give the HO there a try. Most garages are charging £135.9 for HO so how can sainsburys sell it so cheap? Is it any good???I'll let you know. I usually only use shell HO but had to go shopping and I was on empty, like my wallet is now. I HATE GROCERY SHOPPING !!!Filled mine up from empty. £70. Ouch.
