We've just experienced -6 and temperatures are due to go down to -12 this weekend. Apart from greasing the seals with a silicone spray or rubbing Vaseline on, does anyone have an alternative that will work in these temperatures?
pork chop
to be fair in days gone by tallow was used as a lubricant...
wd40 is not rubber safe ;-)
WD-40 Multi-Use Product can be used on just about everything. It is safe to use on metal, rubber, wood and plastic. It can also be applied to painted metal surfaces without harming the paint. Polycarbonate and clear polystyrene plastic are among the few surfaces on which to avoid using a petroleum-based product like WD-40 Multi-Use Product.
It will, however, be inferior, I think to silicone oil in this application...
From the manufacturers:
It will, however, be inferior, I think to silicone oil in this application. That's why I say "at a pinch"
lso go on any caravan forum and its grounds for a beating with a corner steddy brace if you suggest using wd-40 on your car to caravan power plugs... as from experience it attacks the plastic making it brittle yet spray on another type of plastic it will be fine.....
