General  Front Pipe
General  Front Pipe
rosslev
I have been told by Kwik-Fit that I have a hole in my front pipe, looking underneath I think I have found what they are talking about, assuming I'm looking in the correct place (see picture).
Would some exhaust putty be enough to patch this up?
why wonder, let an exhaust gas analyser decide, its the way a leak is spotted at MOT so it is what you should use as well.
patch up the hole using some putty, then drive it for a few days to make sure it has fully dried there is no movement on the repair that would prevent putty maintaining a seal. then take the car to an mot testing station and have an emisisons test carried out (usually free if you ask nicely and go when not busy, but never more than a fiver). if you pass there cant be a leak, or at least not one that is bad enough to worry about or fail an MOT.
i've seen very similar cracks on exactly the same place on several cars so i'm not 100% sure the crack you have found is the hole they were talking about (if there is even a hole)
the most important thing i can say at this point is to never ever go back to quickfit. they cost more, quote for unneccessary work, tell blatant lies assuming you have no knowledge, supply crap quality pattern parts that rot away in no time, hire unqualified kids on the cheap and dont check on the work they do, and worst of all they make you sit in a waiting room with a pushy sales prick who seems to think your tyres need replacing on all 7 wheels you apparently have without even looking at them.
i agree, had front discs replaced at kwikfit...didnt seem to feel much difference after having it done...hmm.
but i think they did replace them as the old ones were blatently scored as the pads were dead when i got the car without realising it. when i braked hard i could here a grinding sound. but still...£160 front discs and pads :O
also, went there to have wheels balanced as the garage who fitted my new front tyres "forgot" to balance them, even when i went back a second time! anyway balancing was £20 and kwikfraud told me one of my rear tyres were:
"out of shape" and "irreparable". Being a skint student i couldnt afford the balancing and the tyre so i didnt have it done. - this was 2 months ago.
went down to my local tyre fitting place last week to get a puncture repaired and asked them to take a look at the rear tyres, i was then told that they were fine and would last another 3000miles :O and they would fix puncture for £8 :O
next time il stick with my local fiat specialist. they had amazing service when i had my uno!
lesson: dont go to kwikfit!
