Hi.
This might be a more general question than just for the panda but here goes;
Front passenger seatbelt has recently started to be very sensitive to being pulled out. You can go maybe a few inches at a very slow pace before it locks and you have to slightly retract it again and again until it gets to the length you want.
It can be fully extended and the easiest way appears to be to pull it up directly out of the pillar panel rather than by pulling through the bolted loop on the pillar. Doing it like this is less sensitive to locking, it still does it but just not as frequently.
There's not been any impact or emergency stops. The belt does work but it's a time consuming pain to get it to where it's needed.
Is this sensitivity something that can be adjusted or is it a replacement part needed?
Thanks for any guidance.
