Technical front fog lights mk2b
When i removed mine to clean there faces up - i took em apart
They are H3 Bulbs
like a h1 but just more of a 501 shape if that makes any sense what so ever
to remove - its all done by touch - but unscrew the back cover - unhook the bracket that holds bulb inplace - disconnect wire - pull bulb out - reverse to refit
Ziggy
Cheers mate. Just want to change them to some xenon ones
:worship:
You might find it easier instead of reaching down through the bonnet to jack the car up so you can see underneath and get under to see whats what
I advise you get yours out first to make sure they are h3, as it could be like the mk2 headlights where different bulbs were used
Ziggy
