Technical Front Driveshaft hub nut torque
DaveLiverpool
Does anyone have the torque setting for a front hub nut on a 55 plate 1.3jtd. It is unusual because its a 24mm nut not the 22mm in the e-learn manual.
If only there was a haynes book !
regards
regards
Hi Dave.
Welcome to the doblo section. ;)
Do you mean 22mm a-f spanner size..
or M22 thread.??
If its the thread.. you can use that from a passenger car as a guide
(Is it staked..?)
Hi, thanks for reply
The thread is 24mm ( 36mm across flats ). The thing is there is no variation of Doblo in e_learn that shows a 24mm hub nut.
First time I've used e-learn, I'm not convinced those eBay discs are accurate at all.
