My Sporting has been making intermittant noises from the front end for a while now and for once my dealer made some progress. It seems the noises are an internal problem within the dampers, and Fiat are working on a fix, which will be applied to my car when available. If they were changed for the existing ones now the problem would eventually reappear. I think the ones for the petrol models are the same as for the diesels, seems a bit odd and possibly why the ride isnt really good enough alot of the time, so hopefully the rates will have been adjusted on the revised ones.
For reference the noises arent constant, and range from a light tinkling sort of like worn drop links, to a heavier thump or knock noise. It seems to vary depending on road surface and temperature.
Also its having a new drivers seat frame fitted and has had some adjustments to the subframe and various fittings tightened up which has had the effect of making the front end feel 'tighter' like when it was newer. Quite why a modern car should need these adjustments however is beyond me, although at least they have been done. I wouldnt want to own it past the warranty period though if this stuff needs to be done annually on top of a service.
At last I can give some kudos to the service dept at Startins Redditch.
