I wanna make my front bumper on bravo look more lowed and thicker it looks to thin. but i wanna do it the easiest and cheapest way lol. I have a bravo 1.2 sx80! i luv it to bits just wanna make it look nicer.
Yeah get a renault laguna splitter, from one of the older models (97-98ish). Some come with vents some without.
This is Keith R's old car.
Items For Sale:
Fiat Bravo/a Passenger Airbag Covers to suit MK1 & MK2, Foglight Switch Panel for MK1 & MK2, Fiat Bravo/a Headlamp Washer Jets, Bravo & Marea Workshop Manuals, Fiat Bravo Haynes Manual &, Fiat Bravo Owners Manual on CD etc...
My sx doesnt even have that standard bumper you have got. it is really thin even if i put the splitter on there it would look crap. Can i get one like urs and put in on mine. will it fit?
Its not my car, as i have the Abarth front bumper. Thats a HLX bumper. You can fit the splitter to your existing bumper no problem, the only difference between yours and the one above is the foglights, its still the same bumper.
But if you wanted to fit a HLX bumper and that splitter then thats fine and it'll fit fine. Just dont buy a HGT bumper as they wont fit right. Must be a HLX.
This is riches Bravo...
Items For Sale:
You can attach the splitter with self tappers or a staple gun.
The HLX bumper will fit a HLX, straight swap. A HGT bumper will fit but wont align with the wings properly as the wings are wider on the HGT but the HLX has the smaller wings like the SX and S.
The splitter is rubber, it can be bent to follow the shape of the bravo bumper. Its slightly too long for the Bravo so you cut a small piece out. Look closely at the pics. Hardly noticable.
Imagine your SX bumper with foglights, thats all it is. You did say you wanted a cheap splitter mod. Here it is. Why pay more for a bumper. You'll then have the hassle of wiring up the foglights, getting a switch panel for your car etc. Lots of time and money if you ask me.
mate if you want a cheap splitter mod keep your sx bumper you havent got foglights to start off with so there will be empty holes unless you going to go and buy foglights, wiring, etc etc bit pointless if u ask me itll look good on the sx bumper
The splitter is usually cut in the middle to shorten it and then screwed or glued to the bottom of your existing bumper! The sx and hlx bumpers are the same except for foglights and headlight washers. If you put the Laguna splitter on to your existing bumper you can add foglights and the washers at a later date! The foglights can be put into your sx bumper.
All you need is foglights and inserts to hold the lights, these can be gotten from Fiat or a scrapyard. You can drop the bumper and on the rear of the bumper you will see circles marked out. You just need to be handy with a knife and cut the circles out, slide the inserts in and screw the lights into the inserts and replace the bumper! If your car is a Mk2 then the wiring will be there and you will be able to connect up the lights just needing a Mk2 switch for the dash. However if you have a Mk1 I don't think you will have the wiring so you will need wire them up yourself and install a switch!
Heya, i have a mk2 1.6 sx, so all i need to add working foglights is the lights, holders and switch panel? the rest is there already? just plug and play type of thing? are there any of parts of the car that can be upgraded that easily?
