Front Bumper
Front Bumper
M
Mike
Hi all,
How easy is it to remove the front bumper for the bravo? will need to be doing it soon so im curious
well..
as far as i looked, not that easy...
i mean..you'll need some time :)
the biggest problem seems to be the two screws that are on the sides of the bumper, on the top, cause they're under everything under the hood :S
Re: well..
It's not bad, it'll just take you a while.
Theres 2 screw under the bonnet between the headlights, about 8 under the bumper, and 2 on each of the front wings. For these you need to jack the car up, take the front wheels off, and remove the front arch lining to get at the bolts. Theres also a clip under each headlight.
Good luck.
mine
mine had the bolts between the lights, and 2 bolts along each wing, and then just two screws underneath, but there are 2 screws for each foglight bracket aswell
C
2
370
colin
C
563
dan brush
N
289
Nuno Costa
N
P
6
476
jords
J
