turbo500
- Joined
- Mar 20, 2013
- Messages
- 251
- Points
- 118
Hello and happy new year to you all! I’m writing to you from the distant year 2017, while most of you are now in 2018
I’m having issues clearing air from my front brake lines. I recently managed to install new rear drums, that I’ve been struggling with for months.
The fronts were changed a while back, new drums, new pads, new copper lines, rubber lines, banjo bolts, brake cylinders, and also new brake pump. When I did those, I bled the brakes and all seemed fine.
Now, with the new rear rotors, I bled the system again, and the rears seemed fine. I did the fronts, and both were full of tiny, fine bubbles. The bubbles stayed in the drained fluid as well. I was unable to clear the fronts.
I read somewhere that the issue could be with the new lines, meaning there is an air pocket somewhere and the only solution is to use a vacuum bleed system or compressed fluid bleed.
Anyone have any suggestions to what I may be doing wrong?
Thanks in advance, and happy new year!
[ame]https://youtu.be/LZ5Bg7cRDuo[/ame]
