Ooooh! Same for the big 19mm bolts which hold the caliper hanger onto the Bravo's hub?
I've had the Tipo's hanger on and off loads of times and never noticed an issue - Plus torque settings are only really valid at new - rust, age, heat cycles etc can change the tightness. The 19mm bolts were super tight, then easy then super tight again with rust buildup... that would give a false reading on a torque wrench.
