Hey D-
have you ever seen this??
It's the 900cc version !
https://www.racedandrallied.com/rally-cars-for-sale/fiat-abarth-cinquecento-trofeo
Yup, the first Trofeo cars were 899s.
Later ones were 1108.
Hey D-
i think that's amazing-
why do you think they went for the 899cc engine..???
did they make Trofeo's post '94, with the 1108cc engine..?
A 900 on Sporting springs and sporting rubber is a great wee thing. I had a Black one for ages as a run around, it loved being thrashed.
Yes the Sporting springs fit fine.Is it possible to fit Sporting springs to a 900... without further modification? I mean, would I have to change suspension arms, for example (or all Cinquecentos have the same ones?)
I ran mine without the roll bar.Is it worthwhile to fit a front roll bar from a Sporting to a 900?
I ran Seicento Abarth sporings & dampers on my 899 Cinq.
Removing the roll bar from a Sporting actually improves front grip in poor conditions as it allows the inner wheel to keep contact with the road.
And finally - I suppose the six-speed gearbox is from a Punto Mk2?
Any info much appreciated - thanks!
Punto Mk1. They did an 1108 Mk1 that was so underpowered it needed the close ratio 6 speed box.
Yes the ARB will fit, you’ll need the brackets to attach them to the wishbones too.Thanks, good to know about using those in a 900. I understand the ARB would be compatible too then.
My Cinquecento will see good-weather urban driving, mostly, with the occasional trip down the motorway... so I think I'll try to find an ARB.
OK, thanks. I understood the Punto 55S was very low-geared, and that's why people try to fit a Mk2 one for normal driving. In your case, of course, an Mk1 would suit you even better!
Allow me to ask you another question: I suppose the 900 cc engine and the six-speed gearboxes found in FIRE cars such as the Puntos are not compatible?
Thanks again and good luck with your present build.
Remember that adding one will increase understeer, so you may want to try it without first.
