I’ve only driven my new toy 10 miles or so, generally it’s very solid for a 57 year old car.
One item I noticed which may need addressing is fourth gear. It seems shift lever throw should travel another 2”. The rest of the gears have that travel.
I’m unfamiliar with the FIAT gearbox in general and have yet to climb under the car to see if there’s an obstruction causing the linkage to not move its entire length.
Another sensation: I’ve tried pulling the knob “harder” into fourth, when I do, I can feel a slight, rapid thumping (that’s a bad description, can’t think of the right word)… not a gear grinding, but maybe like the synchro is attempting to engage the gear.
Fourth gear drives fine, no whining, grinding or other strange noises.
Once, as I was on trailing throttle, decelerating, the trans did go to neutral… don’t know if it was something I did (bump the lever) or the trans itself… like I said, I have 10 miles under my belt and was concentrating on other things.
The seller had “gone through” the trans, new synchros, shift forks seals, etc. Currently, the fluid used is Valvoline 75-90 Synthetic.
A quote from the seller: “Many people will tell you not to use Synthetic gear oil owning to the material of the synchros, the car has new synchros with metal compatible with synthetic fluid. The trans shifts so much better cold with synthetic fluid. A downside is they tend to leak easier and are noisier as the fluid has a lower viscosity.”
One last observation… I went to the garage this morning after the car had cooled down… as I worked the lever (engine off, no clutch), all the gears were available… the lever “hung up” just a bit engaging fourth, but the lever throw was pretty much the same as the remaining gears. Odd…
So… I’m looking for suggestions on how to proceed… and thanks in advance…
