General Foglights
General Foglights
Hi ive just installed a new cd/mp3 player to a 1998 punto and as ive did last time i blow a fuse doing it
Anyway been to halfrods got new fuses and replaced the blown ones but my foglights will not work i have checked every fuse in the main conpartment and glove conpartment and cant find the problem
help please
ty
Sounds a bit random, but have you acutally checked the bulbs themselves?
can't remember where the wiring from the fog switch goes, but have a look at the back of the switches and see if fitting the stero dislodged the wires... worth a try. also as above, check the fuse for the fogs
Rear Fogs - Fuse #8 - 10A - which is the middle one on the bottom row - normal fuse box
Front Fogs - Fuse #2 - 20A - in the auxiliary fusebox - that's in the top of the glovebox
Coincidentally, the relays for the front and rear fogs are in the auxiliary fusebox too
