JamesAtthews
Hi all I'm venturing into that simple area of Italian electrics so I'm reaching out to you!
My cars rear fog light doesn't light up. The bulbs okay but there's no feed to it. As I have been investigating I notice that a relay isn't firing when the switch is pressed. press the front fog light and you hear a click, the rear window isolators and you'll u hear a click, the heated rear window is the same, but from the rear fog light, no click.
I wonder if anyone has had a similar problem, or if someone knows the location of this relay. I've checked all of the fuses and they are all fine (we all know they are where the book says they are!) So I'm now stumped.
A wiring diagram would be helpful in case there is no relay....
Cheers
James
Cheers
James
