General  flywheel problem again.
pip001
weve had the sedici in for a poor starting problem and it turns out its the flywheel again.exessive play apparantly.this was changed along with the clutch two years ago and 32000 miles.its in the same garage.i cant help but be disappointed by the lack off life from the flywheel.they said they fitted quality parts luk flywheel and clutch.is it unreasonable to expect some form of warranty for this or is this the expected life.
Hi
Sorry your having problems.
I don't understand how a flywheel can give you bad starting ?
What year / engine / mileage is it.
I have bad starting on mine to but think its battery or starter motor related as it turns over very very slowly and takes 20 / 30 seconds to fire up.
Perhaps someone on here can shed some light on why a flywheel could give bad starting.
Hope you get it sorted.
Stephen.
apparently with the play in the flywheel it doesn't hit tdc at the right spot and wont start.nearly a week now and surprisingly not heard from the garage.do you think I have any recourse against the garage or suppliers.looking online luk bits supposed to have a long warranty.when they did the job he said he would only fit quality parts.really disappointed with the whole thing.
