Technical Flashing odometer fix?
Allcarz
London
Recently my odometer on my Fiat Bravo T-jet 120 has started flashing. Looking at YouTube I found only fixes for a 500.
Apparently it's due to a failed Blue and module. Has anyone faced this issue with the Bravo? Or know where the module is located should I want to attempt a fix?
Hello,
Flashing odometer means the car CAN cannot identify the one of the modules that was connected, Blue and Me could be a culprit. Check with MultiEcuScan or AlfaOBD which is the faulty module before you remove blue&me.
If confirmed it comes from the blue&me, there should be an eLearn doc on the forum with the wiring diagram and component location + description for the Bravo. Then,
Once removed, proxi alignment would be needed. Make a backup of the original setting before you change anything. The instructions are here: https://www.fiatforum.com/threads/backup-proxi-file-on-mes.494686/
