Flashing engine management light
Dom
I'm always reading on here but it seems Im only posting when things go wrong! Had to turn back on the way to work this morning the car was running rough and then the engine management light was flashing. Now when I've had problems previously the light has come on and stayed on. This time it is flashing if I get over 2k revs and on idle sounds like it's knocking as well as the exhaust making a regular noise. Any ideas before gold ol RAC come out?
Dom
Engine size ?
When was the last service done and what ?
Members Site
It's a 1.2 mk2, booked in for a service on Friday as 13k since last serviced!
get a diagnostic done..could be a sensor.service will do it good
Flashing EM Light
I had this a couple of weeks ago on my 1.2. The fiat gaeage said that its a blip in the system and can also do it when the engine is cold
RAC diag just showed "Random Misfire" How very useful!! Had to tow it to my garage, think it may be the coil pack but the number 2 cylinder that is misfiring is sparking so a bit of a mystery. Off to get the train in to work now, fantastic.
Cheers everyone,
RAC gut checked the plugs, apparently they are all sparking, swapped them over, same problem on same cylinder which confused him. Hopefully my friendly neighborhood garage will be able to fix it nice and cheaply?!!
"blip in the system" ?
is this a later 1.2 with an OBD system (orange engine light with engine symbol instead of red injector light) ?. if so, this means ECU has detected a serious misfire (which will destroy the cat if not fixed)
Owen.
i had that problem they found out that is was my CAT. i replaced the CAT that was making the noise and then its been ok:)
J
2
460
S
I
2
1K
Dark Lurker
J
1
758
Dark Lurker
874
David
A
2
517
Anonymous
A
