Thanks pal thats brilliant I thought they were pretty much the same just wasn't to sure.
Do you know if everything is pretty easy to take out. I not had a look but imagine the front seat just bolted to the chassis and not to sure about the rear seats.
Fronts are 4x Allen keys iirc
You will need to slide seat forwards and backwards to see them sometimes
Rear seats are a little easier to a degree
Lift the bottom bench up - its simply 2 hex or torx there
removing the back of the bench tho can be a little more tricky as the bolts for them stick out into the rear wheel arch;s, which oftern corrode up and snap when a little bit of force is used
Get soaking them while you can and remove the fronts and door cards
You may forwell find Heat is the only option here, but becareful / Danger is 1 side has the fuel lines
Also make sure its a 3dr going to a 3dr, not a 5dr to a 3dr as they will ""fit"" but not function
if you have the splitting rear back part, it may take a good impact driver to remove them, as again, they sit under the car and corrode in like a bitch
If the bolts do come out - give them a darn good wire wheel with a bench or drill setup
or get some elbow grease and a brush going on them
Refit - ensure you apply correct torque settings too
Ziggy
