02 Stilo Aftermarket Radio Installation
Hello
My factory fitted Visteon radio started playing up - the internal FM amplifier was faulty and most times I had to turn the radio up to max to hear anything (even then it sounded tinny!).
I've removed the radio and bought a fascia to replace it which allows me to fit a standard radio.
I'm trying to fit an Aiwa CT-R429MYZ Radio Cassette Player which has standard ISO plugs. However when I connect it to my Stilo's ISO plugs I can turn the radio on but I get no sound at all. I have checked the manual for the original sound system compared to the new one and as far as I can see everything is connected to the right wires as follows:
ISO Power Plug
Pin 1: No pin on new radio
Pin 2: No pin on new radio
Pin 3: No pin on new radio
Pin 4: Ignition Power (Yellow)
Pin 5: Blue and white cable on the plug but no match on the new radio
Pin 6: No pin on new radio
Pin 7: Permanant Power (Red)
Pin 8: Ground / Earth (Black)
ISO Speaker Plug
Pin 1: Right Rear + (Purple)
Pin 2: Right Rear - (Purple & Black)
Pin 3: Right Front + (Grey)
Pin 4: Right Front - (Grey & Black)
Pin 5: Left Front + (White)
Pin 6: Left Front - (White & Black)
Pin 7: Left Rear + (Green)
Pin 8: Left Rear - (Green & Black)
On the new radio I have one cable that is not connected to anything - it is blue and has a 0.5A fuse inline - any ideas what this is for (Power Antenna?).
Any ideas why I am not getting any sound from this radio? I tested it in my girlfriends Seicento and it worked perfectly so it is not the radio at fault.
Any help would be greatly appreciated.
Hello
ISO Power Plug
ISO Speaker Plug
