hi, what part on the linkeage do you mean, there are a few to choose from. The pick up has been laid up for a while and has only developed the gear selection problem when i started it the other day. Will forward the vin to you, thanks!Did you try the dealer?
Almost all parts are still available from Brazil, and not expensive!
About your difficult gear selection, there's a small part at the end of your gear selector, under the car, that will get stuck by rust, put a new one one, and your done, very inexpensive solution.
Give me your VIN and I will look the part # on my parts CD and post it here!
brake compensator... is it a single cylinder type?
82407503 - Brake compensator
7739142 - Bracket
Well, it's actually a kind of small, hollow round metal axle thing, and it's plastic supports, there's a bolt going tru, with a nylock nut.
With the last 8 digits from your VIN, I can give you the exact Fiat part numbers.
Fit a new one with some Teflon grease, and you're done.
(or pry the existing one out, clean it good, grease and refit it.)
Give me the last 8 digits of your vin, and I give you the exact part numbers!
Your Pick-Up is build on 06-1996.
The parts you need are: 7698391 and 82415465 (2X).
Mount it with a lot of (Teflon) grease, and use a new nylock nut to secure it, tighten this nut VERY carefully, to tight=heavy shifting, to loose means vibration noise....
I do have a picture of it all, but don't know how to post it here..???
Parts are very inexpensive (altough you may have to buy 5 of them in one package, policy of Fiat regarding small parts...!), but the bushing WILL corrode over the years and cause difficult shifting, because Fiat Brazil didn't grease it from new.....!!
Good luck.
Good luck.
