Technical Fiorino 1.9td possible?
gateman
leeds
I have a 1998 Fiorino 1.7td, i also have a scrap Tipo 1.9tdi so the question is can i? should i? would also like the gearbox as the stock Fiorino seems very low geared.
Any thoughts? Ta.
The 1,9 is basically an overbored 1,7 engine.
It should be possible to transplant it, but you will likely run into all sorts of (minor) fitting problems....!!
But it would be a challenge!
Thanks for input, it is probably a nut a bolt job would be nice to chat to someone whos done one already.
Think main issue would be getting the Tipo g/box in as it looks a lot bigger, but can just mate engine to standard Fiorino box if needed.
