:bang:Has anybody got the definative answer on the Marea diesel 125 acceleration problem with accelerating. Ive got a 98 marea weekend that refuses to accelerate after cruising in fifth. Is it the MAF or the Airflow meter or fuel filter/air filter.
that sounds just like a sticking EGR, but you've replaced it alreadyAs mentioned the only way around this problem is dipping the clutch letting the revs fall to idle then re-engaging and the car will accellerate.
ah, good pointNo he's just cleaned it, still might not be working correctly.
sounds like its going into a limp mode so.. I would try and see if there are any codes stored via diagnostics before replacing anything else. I don't know the behaviour of these engines (never seen a TD125 over here), but i believe the injector pump is much like an early vag TDI system. I recall someone on the forum having the same problem, the conclusion via a dealership was the ECU was damaged due to a faulty EGR control solenoid valve, and thus was unable to control the EGR and going into limp mode..
its a 98 model TD (not a JTD) so EGR valve is pneumatic and it isnt drive-by-wire.eh.. though I've never seen these engines, my info tells me that there is an ECU, its a throttle pot system (drive by wire), with a fuel quantity and timing adjustment solenoid built into the pump - much like older vag TDI. EGR also has to be controlled by an ECU..
