Fiat stilo
Fiat stilo
Littlej22
Hi every1 I bought a fiat stilo today and it says airbag failure just wondering if any1 knows what it is its a 02 reg 1.2 iv checked all the clips under the seats in the glove box and in the boot and cleaned them all with connector cleaner cheers
Get it code read, since you have covered most bases it may be something to do with the drivers' airbag.
Hi, Welcome to the FF.
Please post any technical issues in Stilo section of the forum here: www.fiatforum.com/stilo
I had one of these and even though you have checked all the plugs and sockets I found on mine that when the seats are constantly moved back and forth and the wires are very exposed under the carpet right up to the front bulkhead. on mine there was a broken wire under the sound insulation under the carpet it was a bitch to find but I found it with continuity tests on each wire after replacing the wires no more problems . the wires run in an indentation in the floor
