Fiat Stilo - 1.6 dynamic Factory Stereo ? inputs ?
mercer
South East London
hey are there any AUX / Phono inputs or sub on the back of a stilo stereo. namely my factory 1.6 dynamic stereo.
i dont have the pins to remove the stereo from the dash.
or is there any way for me to connect a audio lead up somewere to this stereo so i can plug in my phone for music
https://cdn-i.fiatforum.com/images/attach/jpg.g
HERE IS A TUTORIAL ON CONNECTING UP MP3 PLAYERS AND OTHER AUDIO DEVICES.
THE REAR VIEW HERE IS SIMILAR THROUGH ALL RANGES OF FIAT.
BLUE MOLEX CONNECTOR. NORMALLY USED FOR CD CHANGER.
HOWEVER THERE ARE DEVICES AVAILABLE THAT CONNECT TO THIS [YATOUR] FOR EG, IT HAS CONNECTIONS FOR SD CARD [32GB] MAX.
USB PORT FOR MEMORY STICK [32GB] MAX , CAN ALSO CHARGE PHONE ECT.
3.5 SOCKET FOR DIRECT CONNECTION OF ANY AUDIO SOURCE WITH A 3.5 OUTPUT.
GREEN MOLEX. THIS IS A CONNECTION FOR TELEPHONE INTERFACE.
YELLOW. THIS HAS MULTI USES.
BLUE & ME
SEPARATE POWERAMP/SUBWOOFER
MOST COMMON FOR THIS CONNECTION IS AUX INPUT
LEADS READYMADE CAN BE BOUGHT ONLINE THAT ARE PLUG-N-PLAY.
TO ACCESS THIS INPUT, PRESS YOUR CD BUTTON TWICE, YOU CAN ALTER THE INPUT VOLUME ON THE HEADUNIT SETTINGS,YOU ONLY NEED TO DO THIS ONCE,AFTER THAT USE YOUR MAIN VOLUME CONTROL.
CONCLUSION.
THE ''YATOUR'' IS THE FAR BETTER WAY,YOU CAN CONTROLL IT VIA HEAD UNIT [USB/SD] IT IS TREATED AS A CD CHANGER, AND WITH A MAX OF 32GB THATS A LOT OF MUSIC FILES,ALL ACCESSED FROM YOUR STANDARD UNIT.
HOPE THIS HELPS WITH YOUR CONNECTION ISSUES
LUIGI
I bought a Yatour for my Stilo and when I've connected it I don't get any options to select it from my Stereo (just the regular radio and tape) - does anyone know if there is anything else I need to do?
I'd be really grateful for any help
There must be a function/button on you head unit, as your head unit is capable of a cd changer as an option-[yatour]
have you got a manual for the head unit,as this will tell you.
So you have no cd player? , just tuner/tape player?
Luigi
where can buy the plug n play cable,i donno the whether you have different cables for different stereo.I have a Fiat stilo xbox edition with visteon system.I desperately want an aux in but can't find the installation kit.:bang:
You use the SRC button. Bottom left. Remember and name your albums as CD01, CD02, etc or it wont work proper.
hi iv got a still 2002 plate and have a problem with my speakers. Basicly i took of the original HU of to put an aftermarket unit on but my speakers seem the be wired to an amp (as what a audio tech told me) is this true and how would i have to wire up the new unit for the speakers to work (need help)
