Technical Fiat Scudo Petrol Engine
fatrascal
Is anyone out there unlucky enough to have bought a Fiat Scudo 1.6 Petrol - we have and have only had trouble with it.... (They only made them 1997-2001)
The latest problems are due to an overheating engine (that might not really be overheating) and a garage that say they have put everything back correctly after re-fitting the cooler fan. I think they've missed off a shroud which I could have sworn was fitted over part of the upper radiator fan and a simple down-pipe that used to simply hang under the front of the car. I didn't think it was that important but it looks like it allowed the fan to blow the hot air from the radiator away under the car rather than directly onto the engine block.
If you do have the same van,I'd really appreciate it if you could take a photo and post it up here - I need something to take to the garage to show them that they have indeed missed a piece.....
Mark
What 'overheating' (or not) problems were you having?
Has the (possible) lack of shroud made a difference?
