General Fiat punto 1.2 grande no dipped beam headlights
Krandall2011
I hope someone can help me with this problem.
Both my dipped beam have stopped working.
Checked and changed both bulbs - OK
Checked and changed both fuses - OK
Checked and changed relays - OK
Changed stalks and no change
I have run a wire from the battery to the fuses and relay 1 at a time and the light do come on so I know the wiring from the fuse board to the lights is fine.
Thank you in advance if people can help.
I'd say carry on as you are just keep working backwards with a live feed until it stops working.
Can anyone post a wiring diagram to help.
Might be worth checking for a fault code.
Here's the drawing Thomas …
BRs, Bernie
If someone here helped You fix -or better, understand- your issue, hit the thanks icon @ bottom right corner, it's free and makes us feel helpy ;-)
I found the problem, it was wire 27 that was broke inside the block of wires that plug into the fuse board from the main loom, it had snapped I side the block and until I pulled every wire and tested it I found it to have brick.
Thank you for the wiring diagram, it was a help
Thank you
