General Fiat Panda Alloys ?????
WALES
FIAT PANDA WELSH BOY
Needs alloys plz help any one got any fiat panda alloys or modding stuff for my panda help cheers get back to me traxx
Hi, im in Denmark.
Have 5½x13" et16 alloy. Working on at fenderset, whice will give 20 mm wider at front and 30 mm wider at rear.
pandaman71 said:
Cinq, Uno, alloys will fit the Panda
Careful with Uno turbo alloys as they are too wide and require spacers to avoid rubbing problems.
Lancia Dedra alloys fit with spacers - 14"!
Fiat X1/9 alloys bolt straight on - and some of the special edition ones are pretty smart.
Also lancia Y10 (inc turbo) alloys.
Ahhh a wheel question :p *comes out from his hole* Make sure the PCD or stud spacing is for fiat. Its different from virtually any other car. don't think just cos its a 4 stud it will fit. I've had 185/60/14's punto alloys fitted for around 6 months now. They look great and give superior grip round corners etc. They didn't need spacers infact if they had spacers they would rub on the outer wheel arch. But to get them on I had to mod the back suspension and grind a hella'lota metal off. But its all worth it and I've had 5 ppl in the car without any rubbing. Theres someone on here who fitted 15" too with low profiles but they cost more than your pandas worth XD
yeah im the one with 15's with low pros. to be quite honest its not worth it...yeah it looks good but its not a big enough engine to handle 15" wheels plus i had to do alot of grinding to the rear and tapping the inside lip off the arch. 14's is your best bet.
